CDC6C: Frequency correction loop behavior at elevated temperature; SATA controller PLL stability concern
Part Number: CDC6C
We are using the CDC6CA025000ADLFR as the 25 MHz reference clock input for a Marvell 88SE9182 SATA/PCIe controller (XTAL_IN pin, analog crystal input, 1.8V, capable to be fed by an Oscillator according to the datasheet and reference designs). The oscillator is operating at 1.8V supply in normal/fast output mode. The 88SE9182 PLL uses this reference to generate its internal core and SATA clocks.
At elevated temperature (above 50°C), the SATA ports of the 88SE9182 produce link resets and does not appear to boot. At negative temperatures and room temperature the system operates correctly. Replacing the CDC6CA025000ADLFR with a passive 25 MHz quartz crystal (TXC-7M-25MHZ-AAJ) eliminates the failure - the system operates correctly at 50°C with the passive crystal installed.
In an earlier design, the same SATA controller position was driven by a Fox FOX924B (now: Abracon FT5HN) digitally-compensated TCXO. That part caused the same SATA link reset symptom at elevated temperature. The FOX924B was removed from use after we identified two probable causes:
1. Duty cycle deviation - measured at 44–45% / 55–56%, marginal for the SATA controller's PLL
2. DCTCXO discrete frequency correction steps - assumption: the DAC-driven varactor correction produces periodic discrete phase steps, which we believe disturb the 88SE9182 PLL
The CDC6CA025000ADLFR replaced the FOX924B precisely because TI describes its BAW correction as continuous rather than step-based, which we expected to resolve the DCTCXO issue. However, the failure pattern at 50°C is the same(!).
Questions:
1. Correction loop behavior at temperature: The CDC6CA datasheet describes temperature correction as continuous. What is the correction loop bandwidth and correction rate at steady-state elevated temperature (e.g. 50°C)? Does the correction produce any detectable frequency transients - even small ones - during the correction process, or is it truly analog and smooth?
2. Phase noise at temperature: Is characterization data available for the CDC6CA025000ADLFR phase noise profile at 50°C, particularly in the range of 1 kHz to 1 MHz offset? We want to understand whether the correction loop contributes phase noise at frequencies that could overlap with a SATA controller PLL's loop bandwidth (~1..10 kHz range typical).
3. Frequency deviation during correction: What is the peak instantaneous frequency deviation during a thermal correction event at 50°C (e.g. transitioning from 25°C to 50°C, or at steady-state 50°C)? Is this bounded in the datasheet, or is characterization data available?
4. Comparison to plain XO: The 88SE9182 PLL works correctly with a passive quartz crystal whose frequency changes on a purely thermal timescale (seconds). What is the fastest rate of frequency change the CDC6CA correction loop can produce, and how does it compare to the natural thermal drift rate of a passive crystal?
5. LVCMOS drive level on analog crystal input: The 88SE9182 XTAL_IN is designed as an analog crystal oscillator input (internal amplifier, analog biasing). The CDC6CA drives it with a full-swing 1.8V LVCMOS signal. Is there any known concern with driving an analog crystal input with a full-swing LVCMOS output, particularly at elevated temperature where the input's analog characteristics may shift?
What we are trying to determine:
The passive crystal works correctly at 50°C. The CDC6CA fails at 50°C with the same symptom previously caused by a DCTCXO. We want to understand whether the CDC6CA's internal correction loop can produce phase or frequency perturbations at 50°C that - even if far smaller than a DCTCXO's discrete steps - are sufficient to cause a PLL with a narrow loop bandwidth to lose lock.
Any characterization data, application notes, or guidance on using CDC6CA-family oscillators as reference clocks into analog crystal inputs of SATA or PCIe controllers would be appreciated.
Thank you very much for your effort to shed some light on this.
Feel free to contact me any time if you need further information, also by phone.
Clemens Koller
