Hi, Is this part of sheme correct or not?
I use next configuration:
reg0: DC58007
reg1: 9F87806
Fin=20 MHz
R=1
I=4
P=5
F=80
Fout=50 MHz
O=8
Loop Filter: R2=10 Ohm, C2=44uF, C1=1uF.
What values of filter elements are you recommend me to use?
reg0: DC58007
reg1: 9F87806
Fin=20 MHz
R=1
I=4
P=5
F=80
Fout=50 MHz
O=8
Ivan,
Since you are using an LVCMOS_3.3 Input, you should follow the recommendations on page 4 of the datasheet: Pin 30 should be pulled to ground through a 1 kΩ resistor.
Pins 29 and 2 look OK.
With regards to the loop filter and register settings, depending on what kind of loop response you are looking for, the results can vary. The software GUI tool in the software section of the CDCE62002 product folder on the TI Website is very helpful. Please use this to verify your loop filter and register values. Should you find any discrepencies, please reply with the results and I can help you out further. Thanks!
Brandon Vonk
