[NE556] Vcc Ripple Specification
Other Parts Discussed in Thread: NE556
Hello~
Would you please let me know the NE556's Vcc ripple spcecification for nominal operation...?
Thanks... C.W. :)
  • It depends on your requirements. You can check the sensitivity of timing intervals against variations of supply voltage on page 5 of the datasheet
  • Chang-woo,
    In addition to what Albert said, The VCC ripple can be filtered at the CONT pin to limit its effect on the timing thresholds.
    The cutoff frequency of the RC low pass filter is about Fc=1/(21,000*C)
    If the timing interval is much greater than the ripple period (1/F[ripple]) then filtering the supply for the charging resistor should not be required. If the timing interval  is less than the ripple period then the charging current will be modulated by the ripple.
    Ron Michallick
