Other Parts Discussed in Thread: CDCE913, CDCEL913
Hello Everyone,
We are trying to program the CDCE913. All of the drivers are correctly installed, the jumpers are correctly set, and the voltage LEDs are lit.
When the software is started, I press the "Programming EVM Tool" and the "TI Clock Programmer" window comes up where you then press "Find Boards" It successfully finds the CDCE913/CDCEL913(COM10) in the "Select Boards" window and is checked. I'm able to turn on and off in the mini Serial communications window that pops up.
However, when I go back to the first window that pops up and hit "Skip", the "Select Device" window with the green dot never shows that the EVM is communicating. I then hit OK and the large window comes up. Still the green light is dark, and when I press the "Read from Device" button, I get a "Device Not Detected" in the upper right window.
From reading other posts, I have consulted scau026a.pdf and 2086.annexeDebuggingProgrammingEVM.docx.
Can you tell me where I'm making my mistake?
Thanks a lot,
Rick
