Other Parts Discussed in Thread: CDCE925
I've been using the CDCE925 as a clock source and need to be able to turn off the PLLs. Ideally, I would like the PLL outputs disabled by default during power on to prevent noise to the board and any irregular behavior of the DUT when the PLL signal is not being used. Unfortunately, it seems the power down bit cannot be set at 0 by default. Is there any other way to shut down the part after power on other than rewriting this register after every power cycle?
-Mitch
