Other Parts Discussed in Thread: CDCE913
I have a problem with the CDCE913 clock synthesizer during the I2C access.
After a power on, I send an I2C frame by the I2C bus, all works fine, and the synthesizer is programmed with the good frequency.
But if I make a second access to program another frequency, the operation fail.
The slave adress is received by the CDCE913 and a NACK is sent in return and of course the transaction is stoped.
If I turn off the CDCE913 power supply, the next frame will work and the second will fail.
I wonder where is the problem, if you have some tips?
Thank you,
Yann
