Clock for SN65LV1021 Serializer
Hi everybody,
I am currently designing a SERDES interface for ARM and I want to use TI's SN65LV1021 Serializer. I read the datasheet and I am clear about most of the thing. Except the clock. This chip needs a clock signal. It is said that the signal should be LVTTL and it put the timing requirements also. However I am not sure what should I use to generate the clock because there is no recommended circuit and whatsoever.
I know that I might be able to use my ARM's clock or TI's independent clock generator, but I'm not so sure on which one is better.
Please share your experience and expertise. I am not quite sure which one is better.
Thank you very much,
Fajar
