CDCE62005 PLL UnLock
Other Parts Discussed in Thread: CDCE62005
We designed a board with CDCE62005.
10MHz PRI LVDS input and 100MHz LVDS output.
I configure as shown in the attached file. but i just can't get a PLL Lock.
So, I changed the pll lock window, but the result is the same.
Plese tell me the check point.
Kihyeon
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/CDCE62500.ini
  • Your register map reflects a 25MHz LVPECL input, not a 10MHz LVDShttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/48/CDCE62005_5F00_2015_5F00_03_5F00_26.ini input. Here is the updated register map for a 10MHz LVDS input.
  • Thank you Madhu for your reply.
    I was set to as you suggested.
    your suggested is Below.
    81840320
    EB020301
    EB020302
    EB020303
    210A0314
    10000A75
    860F0386
    FD0875F7
    20009E18
    But i changes to the setting suitable for my system. That is below.
    EB840320
    68020321
    68860302
    68860323
    68860314
    10000A75
    865F0386
    FD0875F7
    20009E18
    After Setting I try to Calibration VCO in manual mode Until Set to 1 REG 8.6.
    825F0386
    865F0386
    But doesn't change calibration word and still pll unlock.
    REG8 value is below.
    80009A08
    I use only primary input. However, synthesizer source indicates an auxiliary input.
    Can you tell me any problem in settings?
