Other Parts Discussed in Thread: CDCM6208, CDCM6208V1
Customer will control CDCM6208 by using I2C mode.In normal operation, could we use SYSNCN bit to able the outputs during SYNCN pin is low? Is the bit overwritten?
They are considering pins setting as below.
・RESETN pin = open (High)
・SYNCN pin = pull down it to ground to disable the outputs
・PDN pin = open (High)
After setting initial condition with I2C, we will write SYNC bit high to able the outputs.
Kato
