Other Parts Discussed in Thread: LMX2592
Dear Sir
Please can you also suggest how to maximise the output power of the LMX2592 over the 4.3 to 8.3GHz frequency range and explain the "(characteristic)" capacitance in section 8.1.6 in the data sheet? Is the "(characteristic)" capacitance the equivalent shunt parasitic capacitance of the chosen inductor? What is the output impedance of the RF outputs?
Do you recommend a specific inductor over this range, or could you recommend a balun to use both the true and complementary outputs and convert to single ended operation?
JP
