Other Parts Discussed in Thread: CDCM6208
It is often failed when programming cdcm6208 with I2C . Using oscilloscope to measure, you will see the cdcm6208 did not return ACK (sometimes after sending slave address,sometimes after sending register address, sometimes after sending data).
There is another chip on the same I2C bus(with different slave address), and it is communications normal.
Why CDCM6208 is not return ACK?
