LMK04828 PLL2 doesn't lock
Other Parts Discussed in Thread: LMK04828
I'm working on a prototype that uses the LMK04828 in only PLL2 mode.Input to OSCin is 100MHz,I can't get the PLL2 locked and I see DCLKOUT2 is 125MHz .Do you see any possible cause for this problem.
R0 (INIT)	0x000090
R0	0x000010
R2	0x000200
R256	0x010006
R257	0x010143
R259	0x010301
R260	0x010443
R261	0x010510
R262	0x010600
R263	0x010711
R264	0x010818
R265	0x010922
R267	0x010B00
R268	0x010C02
R269	0x010D00
R270	0x010E00
R271	0x010F11
R272	0x011018
R273	0x011122
R275	0x011300
R276	0x011402
R277	0x011500
R278	0x011600
R279	0x011711
R280	0x011806
R281	0x011943
R283	0x011B00
R284	0x011C43
R285	0x011D00
R286	0x011E00
R287	0x011F11
R288	0x012006
R289	0x012143
R291	0x012300
R292	0x012443
R293	0x012500
R294	0x012600
R295	0x012711
R296	0x012806
R297	0x012943
R299	0x012B00
R300	0x012C43
R301	0x012D00
R302	0x012E00
R303	0x012F11
R304	0x013006
R305	0x013143
R307	0x013300
R308	0x013443
R309	0x013500
R310	0x013600
R311	0x013711
R312	0x013825
R313	0x013902
R314	0x013A0C
R315	0x013B00
R316	0x013C00
R317	0x013D08
R318	0x013E01
R319	0x013F01
R320	0x014000
R321	0x014100
R322	0x014200
R323	0x014392
R324	0x014471
R325	0x01457F
R326	0x014600
R327	0x01471A
R328	0x014802
R329	0x014902
R330	0x014A02
R331	0x014B16
R332	0x014C00
R333	0x014D00
R334	0x014EC0
R335	0x014F7F
R336	0x015003
R337	0x015102
R338	0x015200
R339	0x015300
R340	0x015478
R341	0x015500
R342	0x015678
R343	0x015700
R344	0x015896
R345	0x015900
R346	0x015A78
R347	0x015BD4
R348	0x015C20
R349	0x015D00
R350	0x015E00
R351	0x015F0B
R352	0x016000
R353	0x016101
R354	0x016224
R355	0x016300
R356	0x016400
R357	0x01650C
R380	0x017C15
R381	0x017D33
R358	0x016600
R359	0x016700
R360	0x01680F
R361	0x01695D
R362	0x016A20
R363	0x016B00
R364	0x016C00
R365	0x016D00
R366	0x016E13
R371	0x017300
R8189	0x1FFD00
R8190	0x1FFE00
R8191	0x1FFF53
    I don't see any glaring issue in your configuration.
    Some tests...
    What's the voltage of PLL2_CP output pin? Is it railed or centered?
    If you set PLL2_LD_MUX = 0x12 (PLL2 R/2), do you measure 50 MHz here? (PLL#_LD_MUX cannot = 0x02 or 0x03). Could use PLL1_LD_MUX alternatively.
    If you set PLL1_LD_MUX = 0x14 (PLL2 N/2), do you measure 50 MHz here?
    If you look at both at the same time, are they locked in phase?
    Other configuration notes for power savings...
    Note, you can set PLL1_PD = 1 if you're not using it to save power.
    Doesn't look like you're using the FB_MUX either, so FB_MUX_EN can be = 0.
    TRACK_EN = 0 also if your not tracking the PLL1 tuning voltage.
    HOLDOVER_EN = 0 as you're not using PLL1 / holdover feature.
    You are using device clock on all your SDCLKoutY, so you can set SDCLKoutY_PD = 1. That is only powering the SYSREF side of the SDCLKoutY output. Also set SYSREF_CLR = 0 for steady state operation as SYSREF_CLR = 1 forces the equivalent of SDCLKoutY_PD = 0. [for all SDCLKout outputs].
    The  voltage of PLL2_CP output pin is 0V.
    I just use PLL2 as  I set PLL1_PD=1. I have change the config file (as attached file [lmk04828.mac.txt]).
    Look forward to your reply.
    [SETUP]
    ADDRESS=888
    CLOCK=1
    DATA=2
    LE=3
    PART=LMK04828B
    PINPOSITION00=1
    PINPOSITION01=1
    PINPOSITION02=1
    PINPOSITION03=1
    PINPOSITION04=1
    [MODES]
    NAME00=R0 (INIT)
    VALUE00=144
    NAME01=R0
    VALUE01=16
    NAME02=R2
    VALUE02=512
    NAME03=R256
    VALUE03=65574
    NAME04=R257
    VALUE04=65859
    NAME05=R259
    VALUE05=66305
    NAME06=R260
    VALUE06=66627
    NAME07=R261
    VALUE07=66832
    NAME08=R262
    VALUE08=67072
    NAME09=R263
    VALUE09=67345
    NAME10=R264
    VALUE10=67640
    NAME11=R265
    VALUE11=67874
    NAME12=R267
    VALUE12=68352
    NAME13=R268
    VALUE13=68610
    NAME14=R269
    VALUE14=68864
    NAME15=R270
    VALUE15=69120
    NAME16=R271
    VALUE16=69393
    NAME17=R272
    VALUE17=69688
    NAME18=R273
    VALUE18=69922
    NAME19=R275
    VALUE19=70400
    NAME20=R276
    VALUE20=70658
    NAME21=R277
    VALUE21=70912
    NAME22=R278
    VALUE22=71168
    NAME23=R279
    VALUE23=71441
    NAME24=R280
    VALUE24=71718
    NAME25=R281
    VALUE25=72003
    NAME26=R283
    VALUE26=72448
    NAME27=R284
    VALUE27=72771
    NAME28=R285
    VALUE28=72960
    NAME29=R286
    VALUE29=73216
    NAME30=R287
    VALUE30=73489
    NAME31=R288
    VALUE31=73766
    NAME32=R289
    VALUE32=74051
    NAME33=R291
    VALUE33=74496
    NAME34=R292
    VALUE34=74819
    NAME35=R293
    VALUE35=75008
    NAME36=R294
    VALUE36=75264
    NAME37=R295
    VALUE37=75537
    NAME38=R296
    VALUE38=75814
    NAME39=R297
    VALUE39=76099
    NAME40=R299
    VALUE40=76544
    NAME41=R300
    VALUE41=76867
    NAME42=R301
    VALUE42=77056
    NAME43=R302
    VALUE43=77312
    NAME44=R303
    VALUE44=77585
    NAME45=R304
    VALUE45=77862
    NAME46=R305
    VALUE46=78147
    NAME47=R307
    VALUE47=78592
    NAME48=R308
    VALUE48=78915
    NAME49=R309
    VALUE49=79104
    NAME50=R310
    VALUE50=79360
    NAME51=R311
    VALUE51=79633
    NAME52=R312
    VALUE52=79909
    NAME53=R313
    VALUE53=80130
    NAME54=R314
    VALUE54=80396
    NAME55=R315
    VALUE55=80640
    NAME56=R316
    VALUE56=80896
    NAME57=R317
    VALUE57=81160
    NAME58=R318
    VALUE58=81409
    NAME59=R319
    VALUE59=81664
    NAME60=R320
    VALUE60=81920
    NAME61=R321
    VALUE61=82176
    NAME62=R322
    VALUE62=82432
    NAME63=R323
    VALUE63=82706
    NAME64=R324
    VALUE64=83057
    NAME65=R325
    VALUE65=83327
    NAME66=R326
    VALUE66=83456
    NAME67=R327
    VALUE67=83736
    NAME68=R328
    VALUE68=83970
    NAME69=R329
    VALUE69=84226
    NAME70=R330
    VALUE70=84482
    NAME71=R331
    VALUE71=84738
    NAME72=R332
    VALUE72=84992
    NAME73=R333
    VALUE73=85248
    NAME74=R334
    VALUE74=85696
    NAME75=R335
    VALUE75=85887
    NAME76=R336
    VALUE76=86019
    NAME77=R337
    VALUE77=86274
    NAME78=R338
    VALUE78=86528
    NAME79=R339
    VALUE79=86784
    NAME80=R340
    VALUE80=87160
    NAME81=R341
    VALUE81=87296
    NAME82=R342
    VALUE82=87672
    NAME83=R343
    VALUE83=87808
    NAME84=R344
    VALUE84=88214
    NAME85=R345
    VALUE85=88320
    NAME86=R346
    VALUE86=88696
    NAME87=R347
    VALUE87=89044
    NAME88=R348
    VALUE88=89120
    NAME89=R349
    VALUE89=89344
    NAME90=R350
    VALUE90=89600
    NAME91=R351
    VALUE91=89867
    NAME92=R352
    VALUE92=90112
    NAME93=R353
    VALUE93=90369
    NAME94=R354
    VALUE94=90662
    NAME95=R355
    VALUE95=90880
    NAME96=R356
    VALUE96=91136
    NAME97=R357
    VALUE97=91404
    NAME98=R380
    VALUE98=97301
    NAME99=R381
    VALUE99=97587
    NAME100=R358
    VALUE100=91648
    NAME101=R359
    VALUE101=91904
    NAME102=R360
    VALUE102=92175
    NAME103=R361
    VALUE103=92509
    NAME104=R362
    VALUE104=92704
    NAME105=R363
    VALUE105=92928
    NAME106=R364
    VALUE106=93184
    NAME107=R365
    VALUE107=93440
    NAME108=R366
    VALUE108=93715
    NAME109=R371
    VALUE109=94976
    NAME110=R8189
    VALUE110=2096384
    NAME111=R8190
    VALUE111=2096640
    NAME112=R8191
    VALUE112=2096979
    OSCIN00=122.88
    EXTRA_PLL_N_DIV_1_00=1
    OSCIN01=100
    EXTRA_PLL_N_DIV_1_01=1
    PINS=0
    [BURST]
    COUNT=0
    [FLEX]
    CLKout0_FREQ=500
    CLKout10_FREQ=500
    CLKout11_FREQ=500
    CLKout12_FREQ=500
    CLKout13_FREQ=500
    CLKout1_FREQ=500
    CLKout2_FREQ=125
    CLKout3_FREQ=125
    CLKout4_FREQ=125
    CLKout5_FREQ=125
    CLKout6_FREQ=500
    CLKout7_FREQ=500
    CLKout8_FREQ=500
    CLKout9_FREQ=500
    DCLKout0_DIV_ud=DCLKout0_DIV
    DCLKout10_DIV_ud=DCLKout10_DIV
    DCLKout12_DIV_ud=DCLKout12_DIV
    DCLKout2_DIV_ud=DCLKout2_DIV
    DCLKout4_DIV_ud=DCLKout4_DIV
    DCLKout6_DIV_ud=DCLKout6_DIV
    DCLKout8_DIV_ud=DCLKout8_DIV
    OSCout_FREQ=100
    PLL2_PDF=100
    SYSREF_freq=.9765625
    VCO_freq=3000
    VCXO_freq=100
    sync_SYSREF_freq=.9765625
    sync_VCO_freq=3000
    [FLEXHASH]
    HASHVALUE=11587216
