Other Parts Discussed in Thread: CDCE62005
Requirements: 1. Two ADC clocks Range(20MHz-400MHz) 2. Two DAC clocks 3. Synchronization clock to FPGA
Plz Suggest clock distribution scheme
How about CDCE62005?
Thanks Firtz for the reply...
My problem is external input is 800 MHz sinusoidal. With CDCE62005, input can be either LVCMOS, LVPECL or LVDS and limited to 500 MHz to use in PLL -VCO mode.
Hello Bhupesh,
how about adding a divider into the signal path to reduce the 800MHz down to 400MHz? Here is a device that can do this: http://www.ti.com/lit/gpn/cdcm1804
It's going to increase your total device count but should overall work fine. thank you! Fritz
