I need to generate frequency in the range 10,011 to 10,437 GHz my reference will be 106,5 MHz so an integer PLL.
Can i use LMX2592 alone ( i can accept out signal even at -10 dBm) or i have to add a 2X multiplier ?
The LMX2592 alone will allow 106,5 MHz as Fpd allowing 106,5 MHz channel the insertion of 2X multiplier force me to divide by 2 the reference in order to have the same channeling .
Supposing a very good reference what phase noise at 1 and 10 KHz is possible? Please both solution 5 or 10 ghz output.
Thanks in advance
