LMX2582: Register Map Default values
Part Number: LMX2582
In datasheet rev. feb. 2017 register map default values (Figure 22) is different with Raw Registers in TI CS Pro. If I use incorrect data PLL does not work fully or fractional mode.
R32, R33, R46, R64 is different. It's right?
Please correct the data sheet.
  • Artur,
    The datasheet was actually updated first, if you see revD has those changed values. TICS should be updated to reflect that shortly. Those registers are changed to help calibration times. So your results should not change.
