CDCLVP111: IBIS Model Issue
Part Number: CDCLVP111
I am currently doing some signal integrity analysis on the part driver using Mentor Graphics Hyperlynx and I am running into errors.
Here are the following errors while trying to read the ibis model in:
Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 7 to pin 1 of component CDCLVP111-EPHFG does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 4 to pin 1 of component CDCLVP111-EPHFG does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 7 to pin 8 of component CDCLVP111-EPHFG does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 4 to pin 8 of component CDCLVP111-EPHFG does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLKSEL used by the series pin mapping from pin 2 to pin 8 of component CDCLVP111-EPHFG does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 7 to pin 1 of component CDCLVP111VF does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 4 to pin 1 of component CDCLVP111VF does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 7 to pin 8 of component CDCLVP111VF does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 4 to pin 8 of component CDCLVP111VF does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLKSEL used by the series pin mapping from pin 2 to pin 8 of component CDCLVP111VF does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 7 to pin 1 of component CDCLVP111RHB does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PUP_CLK used by the series pin mapping from pin 4 to pin 1 of component CDCLVP111RHB does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 7 to pin 8 of component CDCLVP111RHB does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLK used by the series pin mapping from pin 4 to pin 8 of component CDCLVP111RHB does not exist in this file.
               Error : at line 2486 in file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs : Pin model PDN_CLKSEL used by the series pin mapping from pin 2 to pin 8 of component CDCLVP111RHB does not exist in this file.
               Error : Parse failed on file C:/MentorGraphics/HDS_2015.1/9.1HL/SDD_HOME/hyperlynx64/Libs/cdclvp111.ibs.
Can someone at TI assist in this issue.
Thank you
