Part Number: CDCM61002
Other Parts Discussed in Thread: CDCM61004, , CDCM9102
The CDCM61004 has a temperature drift limitation of 100°C (indicated in datasheet since revision H January 2016).
The CDCM61002 which is a similar device (but with only two outputs) does not exhibit such a limitation in its datasheet (revision F June 2011).
How can I be sure that the CDCM61002 is not also limitated by a 100°C temperature drift ?
Thank you.
Fred.
