Part Number: LMK04832EVM
I'm using the LMK04832EVM with a 100 MHz VCO , replacing the original 122.88 MHz VCO.
In order to generate all of the required different outputs rates, I need a reference clock of 1000 MHz (2000 MHz is also OK).
I've tried , using TICS Pro, to configure such a frequency, by changing the , R Divider, N divider and N prescaler, and was unable to get a PLL lock.
I've only managed to generate 2400,2500,2600 MHz ref clocks (maybe some other as well).
Can someone help me understand what combination of N & R is needed in order to generate the required frequency?
Thank you,
Gilad
