Part Number: LMX2594EVM
Other Parts Discussed in Thread: LMX2594, LMK61E2,
Object: LMX2594 and LMK61E2 : boards settings problems ---> http://www.ti.com/lit/ug/snau210/snau210.pdf
Greatings,
I'm a student of ‘Politecnico di Torino’ and I'm doing a master thesis using the boards in question. I am writing to you to raise some problems regarding the setting of these boards .
I would like same clarification on how to set up “single ended” mode since this is not clear by reading the information provided on page. 18/36 of the attached pdf.
In addition, it should be noted that the guidelines on how to set up the "differential pair" mode are followed by a scheme concerning the "single ended" mode (pages 17 and 18) and viceversa .
Another doubt to be solved is related to how to carry out the following operations reported in the guidelines (pages 17 and 18):
- Switch R24b to R24;
- Must remove R33 to…;
- Populate R25 and R30;
and what indicates the symbol “X” in red in Figg. 14 and 15 regarding the board LMX2594.
Thanks for your cooperation.
