Other Parts Discussed in Thread: LMX2491
I am stuck with LMX2492.
I can write the data into registers of LMX2492 but unable to readback.
My simple algorithm is as follows:
A. Write
Initial Conditions Clock = Data = low, LE = High, MSB of data = o,
Pull LE Low
Set the data on Data line
Pull clock high
Change the data on Data line
Pull clock low
.(Repeated for 24 bits of data(Address+data for LMX2492))
Pull LE high
B. Read
Initial Conditions Clock = Data = low, LE = High, MSB of data = 1,
Pull LE Low
Pull clock high
Pull clock low
.(Repeated for 16 bits of data(Address for LMX2492))
Pull Clock High
Read Data from Muxout pin (Repeat for 8 bits)
Pull Clock Low
Pull LE high
I verified the write by current change after enabling and disabling the PLL
But while reading, I find MUXout is always low(Using Oscilloscope as well). No activity on it at all.
Please help.
