I plan to use the LMK04610 in my new design. For the CPU in the design I need a running clock right after reset (before chip programming).
For that reason I decided to use the OSCout output that drives PLL1 only (PLL2 bypass mode, figure 53 in datasheet) right after reset and later on I plan to switch to dual PLL mode (with PLL2 figure 51 in datasheet).
My questions:
- What is the SSB (dBc/Hz) phase noise difference of OSCout (at 122.88MHz frequency out) between PLL1 only (PLL2 bypass mode) and dual PLL mode?
- While doing the switching between the above modes should I expect PLL out-of-lock of or any other drift?
Menachem
