Part Number: CDCLVP1204
Hi Team,
Quick question, if customer wants to use 156.25MHz LVPECL output signal to connect with fan out buffer CDCLVP1204 through AC couple cap, what to do the Vac_ref pin?
In the past, customer will bias by external resistor. If this pin is simply for external bias replacement, does is Vac_ref pin provide any advantage? Thanks!
Andrew
