Part Number: LMX2594
Other Parts Discussed in Thread: PLLATINUMSIM-SW
Hi all,
Would you be able to help me to understand my phase noise measurement results done using the LMX2594EVM evaluation board? The first figure below shows my phase noise measurement using an external single ended 10 MHz TCXO reference (should be high quality), which is divided to 1 MHz phase detector frequency. The evaluation board is configured to output at 9.8 GHz. What could be causing the significant difference between the values I can find in the datasheet and the values I am measuring? The second figure shows the settings I used in the evaluation software.
The third figure presents the results I got using the on-board 100 MHz reference oscillator doubled to 200 MHz phase detector frequency. The datasheet and my measurement agree a bit better, but there is still a large difference that starts to grow below 100 kHz. Again, what could cause the large difference between my measurement and the values from datasheet?
You can find the equipment I used in the measurements listed in the table under the figures.
Best regards.
