Other Parts Discussed in Thread: LMX2491
Is it possible to start an automatic ramp with an external trigger (eg. rising edge) and generate a continuous triangle chirp until the ramp is disabled?
I was thinking to use Trigger A for RAMP0_NEXT_TRIG to initiate waveform and then the triangle waveform should run continuously. However, in order to get it to run continuously, I would need to set the RAMP0_NEXT_TRIG to TOC Timeout. Which means that this method would not work. Is there any way to trigger the automatic signal ramp?
