Part Number: LMK00334-Q1
HI:
On the vehicle-mounted EVB designed by us, we intend to use LMK00334-Q1 as CLK buffer .the application environment is:after the vehicle-mounted module PCIE clock signal passes through CLK buffer,three HCSL clocks are extended, one to PCIE switch,and the other two are connected to two PCIE EP. is this design appropriate? thank you.
BR
Sunny
