Other Parts Discussed in Thread: LMX2581, CDCE62002,
Hi There,
I am wondering if LMX 2594 can be used to generate two RF Signals: 500MHz and 1000MHz. TICS Pro can be used generate two RF signals with different ratios at the Output ports A and B as long as Fvco is above 7600MHz. For generating signals at the 500MHz and 1000MHz frequency, the Fvco should go below 7600MHz, and, as a result, the FICS Pro highlights the Fvco value in Red as error. Could you please let me know if I can generate generate two RF Signals at the 500MHz and 1000MHz frequencies? If so, please let me know how to work around the issue.
Ed
