Part Number: CDCI6214
I want to use the CDCI6214 and have some question : The d/s mentions a FOD Calculation document, but we could not find anything about that?
Hi, Thank you for your reply
I want to set the clock output by myself through configuration register, but I don't know how to Fod Calculation, and I can't find anything about FOD Calculation .
Do you know anything about FOD Calculation? If you have any other documents / way about the FOD Calculation : Kindly asking to share!
Thanks and best regards
I have sent you a private message. Let's continue this discussion offline.
Kind regards,
Lane
Can I join this private message because I facing the same problem?
With some IOD not all FOD's generate correct frequencies.
We use 2 output clocks and the same combination IOD/FOD works on the first output and not on the other or vice versa.
Even on the boards which generates the correct frequency, jitter is very bad resulting in malfunctioning of our design.
We have tested it on 20 boards and the issue occurs on more then 4 boards.
Hi Ivan,
I will close this thread but send you a private message.
Kind regards,
Lane
