LMX2592: REFoutA output after power up but before soft reset
Part Number: LMX2592
At LMX2592/4, right after power up but before soft reset, any undesired frequency radiation output could be at REFoutAP/M pins?
K.Hirano
  • Thanks for posting on E2E. I have assigned your post to the responsible engineer. He will respond to you soon.
    Kind regards,
    Lane
  • Hi Hirano-san,
    If CE pin is connected to the Vcc pin. After Vcc is applied to the chips, the internal power on reset (POR) circuitry will put the chips to use the default silicon register setting. Some functional blocks will be up and running, you will see some signal at the RF output.
    If CE pin is tied LOW, after Vcc power up, the chips are in power down state and there will be no signal output.
