Part Number: NE555
Other Parts Discussed in Thread: TL783, TPS7A4001, LMC555, TLC555
Hi team,
My customer would like to use NE555, but the board voltage they have only 48V.
Do you think use a resistor divider to scale down from 48V to 12V is a good way for NE555 VCC pin?
I check the datasheet of NE555 VCC, the maximum supply current of VCC is 15mA, which is high if want to use resistor divider.
Or you will suggest us to use one more buck IC to converter the power?
Thanks.
Allen
