LMX2572: The built-in 32 frequency division is turned on, the output 102.4mhz signal appears self-excitation, and its performance is similar to the loss of lock.
Part Number: LMX2572
Dear TI team,
We use LMX2572 has some questions, would you like give some advice?
When the VCO output frequency is 3276.8mhz. The chip is normally locked.Signal output is normal;However, after the built-in 32 frequency division is turned on, the output 102.4mhz signal appears self-excitation, and its performance is similar to the loss of lock.This phenomenon exists in different reference frequencies and phase discrimination frequencies.After the same pad is replaced with LMX2582RHAR (the pull-up resistance is added to the output pin), the output signal of the same frequency is normal, eliminating PCB board proble
