Dear Sir,
I am using LMV112 in project, application note show's EN1 and EN2 pin is connected to VDD.
so i am putting series resistor between EN and VDD & transistor for EN control will it work?
Vaibhav Rajguru
Dear Sir,
Vaibhav Rajguru
Hello Vaibhav,
What is the use case for the series resistor? How much of a voltage drop will be on it? The EN pins on the LMV112 should be connected to VDD but the spec for the Enable High Minimum Voltage is 1.2 V. You wouldn't want to use a resistor if it would seriously lower the voltage from the VDD value.
Adam
