Part Number: LMK61E2EVM
Other Parts Discussed in Thread: LMK61E2, LMK61E0M
Hi Team,
I use TICS Pro to generate the desired output frequency. Below is my loop filter and PLL setting. I set output frequency = 18.75MHz, but the result is 18.75*4=75MHz. Could you let me know which factor cause 4times difference? I think it may be a part coefficient difference between LMK61E0 and LM61E2
So if I would like to generate the 75MHz output frequency in LMK61E2, I need to set output frequency=75MHz/4=18.75MHz, right?
And I could follow the register setting(set fo=18.75MHz) directly, right?
Roy
