Part Number: LMX2594
This is a continuation from https://e2e.ti.com/support/clock-and-timing/f/48/t/907072
setting DEN = 10000 did improve the walking spurs but have degraded the spur performance as a result.
can you please assist with the following questions.
1. is the walking spur more susceptible if both LO's are using fractional values?
2. does the order of the modulator make a difference when using the DEN values?
3. should they use DEN = 10000 on all fractional values?
4. could using a larger DEN at rational numbers improve spur performance?
5. 1st and 3rd order modulators have given better spur performance while 2nd order has not been nice. is this typical?
Kevin
