LMK04826: TICS Pro : current consumption "menu" not shown
Part Number: LMK04826
Other Parts Discussed in Thread: LMX2582, LMK04208
I'm trying to calculate the current consumption of my design (based on LMK04826) using TICS Pro. But the menu item is not shown on the left pane. It only shows :
It's also not shown if I select different PLL chips (like LMX2582, LMK04208).
What went wrong?
  • Hi Joachim,
    At this time, only some of our TICS Pro device profiles support supply current estimation.
    I believe at one point the LMK0482x family devices did have the current calculator available, but we may have accidentally reverted to an earlier build of the device profile without realizing it. I'm not sure about LMK04208; I have some development files which suggest we started implementing a current calculator, but the implementation is incomplete. LMX2582 does not have current estimation capability in TICS Pro.
    LMK04826B_v3.2.1_CurrentCalc.zipI have attached a zip file which contains the user device profile for the LMK04826 with the current calculator included. Instructions for installing the user device are as follows:
    1. Save the zip file to your computer
    2. Open TICS Pro
    3. In the "Select Device" menu, click "Import User Device"
    4. Select the zip file you saved
    5. From the "Select Device" menu, the user device is now accessible under the "User Devices" menu option
  • Thanks Derek,
    it's working !!
