Other Parts Discussed in Thread: CDCE913
I'm looking for a recommended functional replacement for the LTC6908-1. I need a TI equivalent but the reference tool didn't return any results for this device. Any suggestions would be appreciated.
Lane,
I wold indeed need a device that doesn't need to be programmed. The clock is just being used to send a redundant signal through an RS 485 isolator for emissions evaluation. The clock signal itself just needs to be 3.3V and have variable frequency between 50kHz and 250kHz at 50% duty cycle. Maybe something else can fit the bill? Something along the lines of a 555 timer?
Respectfully,
Lucas
Hi Lucas,
I agree, a 555 timer is a better fit here, especially if you do not require SSC. 555 timers are supported by a different team; could you submit a new post for the 555 timer device so that it is directed to the proper forum?
Kind regards,
Lane
