Part Number: LMX2595
Other Parts Discussed in Thread: TIDA-01346,
I am interested in what the maximum power going into the reference input (OSCinP / OSCinM) can be at 100 MHz.
This is a 50 ohm system and the OSCinP and OSCinM pins are each AC coupled through a 0.1 uF capacitor with 50 ohm resistor shunt to ground. My 100 MHz reference source is single ended so only the OSCinP pin is driven.
The data sheet specifies the maximum drive level as 2 Vpp (+10 dBm in a 50 ohm system), but I would like to drive it with something closer to 13 dBm. Will that be a problem? At what power level does it become a problem?
Thank you,
Tony
