Part Number: CDCE72010
Hi Team,
Customer is using CDCE72010:
Output1: LVPECL, divide by 1
Output2: LVCOMS, divide by10
Customer wants to know how to determine the skew btw Output1 & Output2, thanks!
Andrew
Hi Team,
Andrew
Hi Andrew,
0 skew is impractical, unless you use the delay adjustment to manually reduce the skew. Since the divider value for both outputs are not identical, I expect the skew will be a few ns.
Hi Noel,
Sorry, I guess you probably mis-understand my question, I was asking for the how much skew btw Output1 vs Output2 would be if customer set config as below
Output2: LVCOMS, divide by 10
Since datasheet didn't specify it, so any rough number that would make sense should be ok to provide to customer, thanks for help!
Andrew
Andrew,
As you can see from the table, if all the dividers have the same divide ratio, the skew is xxps. However, if the divide ratio are not the same, the skew goes up to >1ns. There is also a xxxps skew between CMOS and LVPECL. So my guess is a few ns in customer's configuration.
Hi Noel,
I have further question, let me take this offline discussion, thanks for helping out!
Andrew
