Part Number: LMX2594
Other Parts Discussed in Thread: LMK00304
Dear Support,
We are using a single-ended 50MHz reference input that is AC coupled to the LMX OSCinP port. The OSCinM pin is AC coupled to ground. Caps are 0.1uF.
The LMX2594 datasheet indicates that VOSCIN should range from 0.2 to 2Vpp. I assume these limits apply when measured directly at the OSCinP pin and are referenced to ground.
How important is this 2Vpp max value?
Can TI offer suggestions for a voltage limiting circuit with minimal phase noise impact?
Thank you.
Geoff Kline
