Part Number: LMX2592
Hi Sir,
could help confirm and provide suggestion as below question,thanks.
customer currently using LMX2592 output is LO: 18.84375 GHz.
OSC in is a 10Mhz external signal, and the OSC 10Mhz input range is -15~+10 dbm.
at present, when the OSC 10Mhz input= 0dbm & -15dbm is tested, but the phase noise difference is 8dB, is this the correct range?
