When the registers were set while the reference signal wasn't input to the LMX2594 and the registers were set again after the reference signal was input, the symptom occurred that PLL doesn't lock.
The interval between setting when the reference signal isn't input and resetting when the reference signal is input is about 10 ms.
So, is there a possibility that LMX2594 will not be locked under the above conditions?
Please let me know if you would need the register setting for LMX2594. I can share it with you via a private message. So, could you please accept my friendship request?
Kato
