Other Parts Discussed in Thread: TICSPRO-SW, ,
Please provide supply current metrics on each of separated pins in different modes. For example if VCCBUF is how the doubler is also supplied, provide buffer ON/OFF current, doubler ON/OFF, etc. It should be easy for the designer to add up requirements for his own use of 1 output or 2 outputs, SYSREF on or off, Ext/Int PFD mode, Ext/Int VCO mode, fractional vs. integer mode etc.
-Jake
