Part Number: LMK04832EVM
Other Parts Discussed in Thread: LMK04832
HI,
Can you please share the schematic (Orcad files) and Layout files of the LMK04832 eval board.
Yuval
HI,
Yuval
HI,
Please send me what you have. I will try to convert them to Allegro.
Also if you have the schematic in PDF format, it will be useful too.
BTW, do you have the ability to convert it to allegro/Orcad.
If you do then please send me the converted files.
Yuval
HI,
I did not see the schematic.
Can you send it in CAD and PDF format?
Yuval
Hello Yuval,
The HSDC004B (2018-01-23 1-00-36 AM)_for_sharing.zip is the (altium) cad version. Are you able to import? If not, what version of allegro or orcad are you using?
Does the EVM User Guide suffice for the PDF version?
73,
Timothy
HI,
1. I am not able to import
2. I am using Orcad v17.2
3. I saw the scheme in the "EVM user guide" but it is not friendly. You can not use the search function or look into device details.
Yuval
Ok, I understand. We'll see if we can get this exported and the PDF info over to you.
73,
Timothy
Hi Yuval,
We ran into some unforeseen difficulties and we didn't get this out to you before the holiday, apologies for the delay. We'll get back to you on Monday Dec 28th, after US holiday.
Hello Yuval,
I've attached the requested files. The schematic can be used to search for components, however I do not have a way to check the OrCAD files. I used the altium export to generate these. Please make sure to double check the components on the OrCAD file with the schematic and EVM user's guide.
Vibhu
Hello Yuval,
Vibhu
0028.HSDC004B_schematic_OrCAD.zip5100.HSDC004B_schematic.pdf
