Part Number: AMC7832
Hello TI Team,
I am trying to communicate with an AMC7832 chip with an emulated spi protocol over JTAG.
The boundary scan vectors are changing rather slow in respect to a properly clocked spi protocol but I am able to read registers correctly either in stream or individualy.
The problem seems to be that I cannot write to any register. I tried to write on interface config 1 so to enable single instructions but when I read back I get the default values. This also happens with all registers.
On the datasheet the information is not clear but I presume write bit is '0' and read bit is '1' on both single and stream operations. Could you confirm?
Also does the AMC7832 has maximum timing requirements for spi communication?
Thank you.
