I want to measure temperature of a small furnace with accuracy of 0.01 Degree.
I want to read two channels. I am planning to use PT1000 sensors for better resolution.
The temperature range I want to monitor is 0 Degrees to +400 Degrees.
My sampling rate can be as low as 10 samples per second per channel ( i.e. 20 samples per second ).
I can use external reference, and dual power supply if required by the design.
Can you suggest me, whether this IC is suitable for my application ?
Abhijit Gajare
