ADC34J44EVM: Maximum Sample Rate and available config files
Part Number: ADC34J44EVM
Other Parts Discussed in Thread: LMK04828
There are 3 available config files for the ADC3xJxxEVM using the HSDC Pro GUI  - 80 MSPS, 128 MSPS, and 160 MSPS. I am using the ADC34J44EVM where the maximum clock frequency is 125 MHz. Is there any reason that a 125 MSPS config file is not available instead of the 128 MSPS?
If I use the 128 MSPS config file and set my sampling rate to 128M, is there anything I should be weary of given that it is greater than what has been rated as the maximum clock frequency?
CK
  • Hi CK,
    Functionally, the 128 MSPS configuration file will work for the ADC34J44EVM; However, performance may not coincide 100% with data sheet specifications.
    Dan
  • Thanks, Dan. If I wanted to update the config file to 125 MSPS, how would I do that? I've been seeing more of a performance degradation with increased frequency than would be expected if compared to table 7.10 of the spec sheet and now I'm wondering if this might be my issue.
    -CK
  • Hi CK,
    Please try the attached procedure, which utilizes a signal generator as an input to the LMK.
    6305.External Clock.zip
    Dan
  • I'm just trying to understand why it is possible to operate at 128 MHz but not 125 MHz using the 100 MHz VCXO on the EVM board. I understand that 80, 128, and 160 are all values obtained by dividing 2560 MHz by divider values set in the 0x100 register, but I haven't figured out how 2560 MHz is being generated from the 100 MHz VCXO. Its not always going to be convenient for me to have a signal generator with me while operating this, so I would like to understand if it is at all possible to get to 125 MSPS with just changing the config files.
  • Hi CK,
    You are absolutely correct. This frequency can be generated by the LMK using the software TICS Pro.
    http://www.ti.com/tool/TICSPRO-SW
    You can generate register settings for a desired frequency. I have created a configuration file for 125 MSPS operation for the ADC34J44EVM, but it appears that there is a 100 kHz difference in frequency. I input a 1 MHz signal, and the FFT shows a 999.451 kHz signal.
    I do believe that the LMK04828 is capable of producing a solid 125 MSPS based off of the 100 MHz input reference, but I do not have the expertise to troubleshoot this issue further. Please make a post in the HSDC-CTS forum for further assistanceADC3xJxx_125MSPS_Operation_LMK_SettingC.cfg.
    Dan
