Can anyone tell me what is in input voltage for this adc? shall it work for 2-Vp-p input?
If i feed 2Vp-p voltage for generator,It will take or not.
Hi Dan,
As per your above reply if i apply input like below signal . ADC will work fine. Is it So?But in my case when i applied input signal (below) it work fine and i will increase further then it will saturate
Please suggested any change
Hi Nirbhay,
Both of these diagrams that you provided are correct. The first diagram will sum both of the inputs to a total of 2 Vpp (datasheet max), and the second diagram will sum to 400 mVpp. If you exceed 2Vpp, yes, the ADC will saturate.
Dan
Hi Nirbhay,
Are you determining that the ADC is saturated by looking at the output codes? Can you please check to see if the output data format is corresponding to what you expect to see (pin 8 is used to set output format)?
Can you please share the ADC schematic?
Dan
