We have FMC150 board which has DAC3283 chip. I want to use the DAC with real (only I) input and output. Thus I have searched the datasheet of the DAC3283. I found that CONFIG19 register has bequalsa and aequalsb configuration.
- What is the function of this configuration bits? Does setting bequalsa or aequalsb change the data interface protocol? (http://www.ti.com/lit/ds/symlink/dac3283.pdf - page 29)
I also found that CONFIG24 register has sleepa and sleepb configuration.
I will ask the same question here. Does setting sleepa or sleepb change the data interface protocol?
In the above configuration we need only one channel. Should I send the unused data to the DAC as in (http://www.ti.com/lit/ds/symlink/dac3283.pdf - page 29) ?
Muhammet ÖZGÜR
