Other Parts Discussed in Thread: REF5025,
ADS8361 output is 0 or FFFF. Could anyone help to check the mistake? Thanks.
Schematic,
Timing diagram
Output (Test waveform)
Hi Walsh,
The schematic shows that you are using an ext reference REF5025.
The REFOUT pin is the output of the buffered internal reference, and I suspect that connecting this pin to GND may be causing an issue.
Looking at the ADS8361EVM evaluation board schematic, the REFOUT pin can connect to REFIN when using internal Reference through jumper W1, and
REFOUT is left floating when using the ext Reference by removing W1.
http://www.ti.com/lit/ug/slau094a/slau094a.pdf
Is it possible to disconnect the REFOUT pin from GND to see if you get valid conversions?
Thanks and Regards,
Luis
