looking at the GUI interface it seems that SERDES_REF=DAC_PLL output / (Prescalar*Divider).
In the datasheet i do not see the Prescaler which has a fixed value of 4.
Can you explain please?
Best Regards
F,
Your equation is true if you are not using the DAC PLL. If you are using the DAC PLL, replace DACCLock with DAC PLL in your equation. Why is this a concern? Are you having issues with your setup? The PLL's are connected as shown in the GUI block diagram.
Jim
