Other Parts Discussed in Thread: ADS122U04
I am new in ads converters and I realy need help. I have build my own circuit using ADS122U04IPW to measure current and voltage. For communicating I am using USB com port and FTDI chip to talk with ADS.
Until now I have successfully reset and start ADS true COM port (see picture):
A dot appears always when I send command START/SYNC, so I guess that communication work fine. I also measure the course of communication between ftdi and ADS122U04IPW and apparently is working fine.
The problem start when I send command RDATA or RREG to read data from ADS but I never get back a response from ADS. What could be wrong ?
Is this good that I get only "DOT (hex: 00)" back after send START/SYNC and RESET command ?, is there any program to communicate easly with ADS122U04IPW to read data from AIN0, AIN1, AIN2, AIN3 ?
I tried everything what is in poor datasheet and I can not make it work properly :(
Thanks, Matej
